Client Credentials
On the Clients home page, select the appropriate Client record you want to create client credentials.
Click Client Credentials subtab.
Enter the Username and Password, the client system should use to authenticate with the Token Proxy Service. The Username must be unique.
The passwords must be at least 8 characters in length and contain:-
One upper case letter
One lower case letter
One number
One special character from the list: ! " # $ % & ' ( ) * + , - . / : ; < = > ? @ [ \ ] ^ _ ` | ~
These values should match the values set in OPERA on the Config | Setup | Property Interfaces | Interface Configuration | <OPI Interface Record> | Edit | Custom Data tab.
Click Create.
Parent topic: Configuring Clients
