Creating and configuring PSPs
Revocation Check
On the TPS home page, click Payment Service Providers tab.
On the Payment Service Providers home page, click Create New Payment Service Provider.
Enter the Name and Description.
Host: Enter the URL provided by the partner. For example if the URL provided by the partner is https:// myhost.us.example.com:port/token.do, then enter only myhost.us.example.com in the host field and do not append https://.
Port Number: Enter the port number to connect to the partner. For example: 8788.
Context Path: Enter the context path provided by the partner if any.
Enter the PSP’s Failover Host, Failover Port Number and Failover Context Path if the PSP has failover services available.
Connection Timeout (in milliseconds): The number of milliseconds TPS will wait when initiating a connection to the PSP Host before timing out.
Communication Timeout (in seconds): The number of seconds TPS will wait for a response from the PSP Host before timing out.
Select the Payment Service Provider is active option to allow the PSP to be chosen when creating a client.
Enter the Proxy Host and Proxy Port details if the outbound access to the PSP should go via a proxy. These details are optional proxy host settings for anonymous HTTP.
Click Create.
Restart the OPI Token Service for the configuration to take immediate effect. Always restart the OPI Token Service after creating or changing a PSP.
Deselect the Payment Service Provider is active option to set a PSP to inactive status.
