Proxy Configuration
Proxy configuration may be required in an environment that requires a proxy to access the internet.
Cert Manager will
access the internet for the purpose of certificate revocation checks,
and to check and download any missing intermediaries in your certificates
chain of trust.
To configure a Proxy, go to the Proxy configuration in the main screen or use globe icon
when options are selected. -
Check the Proxy Enabled option, enter the valid information as required and select apply.
Parent topic: Tomcat - Certificate Configuration Wizard
