Preface
This document is designed to offer guidance for sizing a deployment of Oracle Self-hosted Token Proxy Service (TPS), as well as provide minimum specifications for hardware purchases. The sizing recommendations published in this document are based on analysis of data collected in test labs and designed to provide guidance on the transaction volume that can be supported on specific hardware.
Due to the fact that many environments have nuances specific to them, these guidelines should be used as a starting point when selecting server hardware. Once a system has gone live in the production environment, it may be necessary to modify the server configuration to account for customer specific requirements and conditions.
For customers with higher transaction volume requirements than what listed in this document, a more powerful hardware configuration shall be considered.
Audience
This document is intended for customers and consultants that require guidance for estimating the server needs of TPS users.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/.
Revision History
Table -1 Revision History
| Date | Description of Change |
March 2025 |
Initial Publication |
