Before Running
To use Cert Manager to deploy your Token Proxy Service certificates, Cert Manager should be able to connect to the Token Proxy Service database, in order to read configuration.
Therefore in a new installation scenario the Token Proxy Service database connection details must be defined before using Cert Manager using the OPIConfigX utility.
Cert Manager performs the similar certificate functions to the OPIConfigX utility, which can also be used if required.
