Installation Prerequisites
Before installing the Token Proxy Service, verify your environment meets the following requirements:
  • 64-bit host
  • Windows Server 2016, 2019, 2022 and Windows 11
  • You can install either Oracle or MySQL database:
    • Oracle 19c database server installed and running, and the user understands how to use and configure Oracle DB.
    • MySQL 8.0 database is installed and running.
  • WebLogic running to host the Web Portal and the user understands how to use and configure WebLogic 12c. This is not required if you want to deploy TPS using Tomcat.
  • An SMTP server exists for sending emails to users.
  • JRE (Java Runtime Environment) 1.8 u261. If Token Proxy Service is installed on the same host as WebLogic (which includes JDK), a separate JRE for Token Proxy Service is not required.
Token Proxy Service 19.3 has the following options for database and deployment:
  • Supports Oracle 19c database and allows deployment of Token Proxy WebPortal on WebLogic.
  • Supports Oracle 19c database and allows deployment of Token Proxy WebPortal on Tomcat.
  • Supports MySQL database and allows deployment of Token Proxy WebPortal on Tomcat.
