Manage Audits
System Administrator can export records in Excel format and also
purge any Audit events that are older than 90 days.
On the Audits page, click more actions at the bottom of the page to export and purge Audit records.
Export
Select Export all records option and then click Export to export all records in Excel format.
Select Export filtered records option and then click Export to export only the filtered records in Excel format.
Purge
Enter the date in the format dd-mm-yyyy, or click the calendar icon
and select the required date and then click Purge to purge any Audit events that are older than 90 days.
