Manual Deployment/UnDeployment on Weblogic
If you want to manually update the Weblogic deployments, you must first manually undeploy the existing deployments.
Login to your WebLogic's admin console.
Navigate to the Environment | Deployments tab.
Select 'Lock and Edit' the configuration.
Select the tickbox next to the 'token-proxy-webportal' deployment.
Select 'Delete' to remove the deployment.
Select 'Yes' to confirm the deletion of the deployment.
Select 'Activate Changes'.
Installation of the new Deployments will be as per the steps listed in the section 'Manual Deployment on WebLogic'.
