Modify
Allows you to add new features or remove already installed components.
If you select the Modify option, then the installer attempts to install each component selected and removes any components that are not selected, regardless of what components are already installed.
For example, if the host machine already has the service component installed and Modify has been run:
If the Datasource, Web Portal and Service are selected, then the installer will attempt to install all three components.
If the Datasource, Web Portal are selected and Service is not selected, then the installer will install Datasource and Web Portal components, and removes the service component.
If the Datasource, Web Portal and Service are selected, and they are already installed the installer will do nothing.
