The Web Portal
The Web Portal is used to configure the settings used by the Token Proxy Service.
The Web Portal is a web application supplied in a WAR file suitable for hosting in WebLogic or Tomcat. It relies on the selected web server to store some of its configuration, such as the database connection string (datasource), and to provide a trusted SSL certificate for connections from users accessing the configuration web portal.
