Installation and Configuration Guide Certificates Request using Cert Manager Wizard Mode - Login Wizard Mode - Login The Login screen has two options such as Tomcat and WebLogic. You need to select either Tomcat or WebLogic option and specify valid connection details and credentials to configure the certificates.
