Client Credentials
You can create the client credentials once the client details are created.
  1. On the Clients home page, select the appropriate Client record you want to create client credentials.
  2. Click Client Credentials subtab.
  3. Enter the Username and Password, the client system should use to authenticate with the Token Proxy Service. The Username must be unique.
    The passwords must be at least twelve characters in length and contain:
    • One upper case letter
    • One lower case letter
    • One number
    • One special character from the list: ! " # $ % & ' ( ) * + , - . / ; < = > ? @ [ \ ] ^ _ ` ~
    These values should match the values set in OPERA on the Config | Setup | Property Interfaces | Interface Configuration | <OPI Interface Record> | Edit | Custom Data tab.
  4. Click Create.
