Configuring Argus Bridge for document management
This section applies only to Argus Safety.
Integrate the document management system to be used with by Oracle Argus Safety configuring the details in Console. By default, Documentum is supported out of the box. Any other document management system can be integrated through the API adapter.
You can access Bridge Configuration from Console > System Configuration > Webservice. This menu is visible only if you belong to groups with access set to Enabled on the Webservice screen in Console > Access Management > Argus > Groups > Menus > Webservice.
To configure the Webservice for integration with any Document Management System:
  1. Go to Console > System Configuration > Webservice > Bridge Configuration.
  2. In the Service Assembly section, enter the following parameters:
    1. In the Service drop down, select Document Management.
    2. In the Class Name field, enter the class name available in the DLL.
    3. In the Assembly File Name field, enter the DLL file name created for the Document Management System.
      To use the default documentum class name, leave the Class Name and Assembly File Name fields blank.
    4. In the Configuration JSON File, upload the configuration file for any system: documentum or other. Before uploading the JSON file, replace the following parameters with your required values:
      • {SERVER_URL}
      • {SERVER_PORT}
      • {THIRD_PARTY_REPO}
      • {USERNAME}
      • {PASSWORD}
      • {CABINET_ID} with {category}
      The sample tags mentioned here are applicable if you are using the default document adapter for documentum. If you are using any other system, then the JSON file may differ according to the custom adapter.
    5. In the Service Status field, status of the Document Management System appears as:
      • Not configured
      • Configured
      • Argus Safety API Load Balancer URL is not configured
        You can configure the API Load Balancer URL option in the default enterprise. For more information, see Configuring Network Settings.
    These settings are applied at global level and not enterprise specific.
  3. In the Service Settings section, enter the following parameters:
    1. For the Enable searching and attaching files already existing in External Storage to a case radio button, select whether to enable search or to attach the existing files to a case that are available in the external storage.
    2. For the Enable storage of case attachment files radio button, select whether to store case attachment files in the Argus storage or external storage.
    3. For the Enable storage of ICSR reports radio button, select whether to store the ICSR reports in the Argus storage or external storage.
    4. For the Enable Storage of submitted expedited reports radio button, select whether to store the submitted expedited reports in the Argus storage or external storage.
    5. For the Enable Storage of submitted periodic reports radio button, select whether to store the submitted periodic reports in the Argus storage or external storage.
      • When the periodic reports are marked as Approved, report are stored in the document repository with a submission_succeed attribute marked as 0.
      • When the periodic reports are marked as Submitted, the report are updated in the document repository with the existing submission_succeed attribute marked as 1.
    6. In the Case Attachment Document Type field, enter the type of attachment being uploaded.
    7. In the ICSR Document Type field, enter the type of ICSR document being uploaded.
    8. In the Expedited Document Type field, enter the type of expedited document being uploaded.
    9. In the Periodic Document Type field, enter the type of periodic document being uploaded.
  4. Click Save.
  5. When the configuration is complete, perform an IISRESET for the settings to become effective.
Upload Document Management Adapter DLL file on a Web server
Follow the steps below to place the adapter DLL file created in step 2 above in the correct folder for each Web server:
  1. Open the argus.ini file and navigate to the ArgusInstallPath folder location, for example: C:\Program Files\Oracle\Argus\ArgusWeb\ASP\.
  2. From the ArgusInstallPath folder, go to the Argus.NET\bin\AdapterBin folder.
  3. Copy the Document Management Adapter file inside the AdapterBin > DOCUMENT folder.
  4. Go back to the ArgusInstallPath, but this time go back two folders to the Argus folder, for example: C:\Program Files\Oracle\Argus.
  5. From the Argus folder, go to API\Bridge\AdapterBin.
  6. Copy the Document Management Adapter file inside the AdapterBin\DOCUMENT folder.
