What are the prerequisites to load a dictionary?
Before you load or overwrite a dictionary, make sure you have the following:
  • Locally saved and zipped dictionary files.
  • MDB/Configuration file—This file is shipped with Oracle Argus and it is available in <Installation path>\Oracle\Argus\DBInstaller directory. This file is automatically selected and used by Oracle Argus based on the dictionary type.
  • Access to Dictionary Loader—The user must login through the default enterprise and must belong to a user group that has the Dictionary Loader option enabled under Access Management, in the Groups window, in the Menu section.
  • Running RelsysWindowsService.exe back-end service. Make sure that the RelsysWindowsService.exe.config is updated with the database details as mentioned in the Oracle Argus Safety and Oracle Argus Insight Installation Guide.
The application does not need to be restarted after loading and there is not a required downtime.
