Create a Fresh Oracle Argus Mart Schema
  1. Log in to the Oracle Argus Mart Server with administrator privileges.
  2. Navigate to ...\ArgusMart\Database\DBInstaller.
  3. Open Dbinstaller\dbinstaller.properties file.
  4. Modify the following parameters:
    • Mart Database:
      • db_connect_string—connects to the Oracle Argus Mart database.
        Syntax: db_connect_string=<host>:<port>/<service name>
        For example:
        server.us.xx.com:1521/AM84MT
        or
        server.us.xx.com:1521/AM84MT.us.xx.com
      • dba_user—specifies the name of the Install user to run Oracle Argus Mart Liquibase Install.
        See Create the Install User in Oracle Argus Mart.
      • default_datafile_directory—default location on the database server, where datafiles will be created.
    • Mart User of each schema, where password is optional:
      • appschema_sm_mart
      • appschema_sm_stage
      • appschema_sm_app
      • appschema_etl_user
      • appschema_rls_user
      • appschema_bi_user
    • Safety Database:
      • safety_db—Oracle Argus database instance name
      • safety_ro_user—Oracle Argus Mart Read-only user created in Oracle Argus
    For more information on these parameters, see Overview of the dbinstaller.properties file.
    It is recommended that you preserve the default names for tablespaces and roles.
  5. From the command prompt, go to the DBInstaller directory.
  6. Type dbinstaller.bat, and press Enter.
    The Liquibase install begins, and the parameters (as entered) appear on the command prompt screen with password in the hidden mode (****).
  7. Keep monitoring the Liquibase progress by querying the Liquibase Log table mart_dbchangelog, created in AM_MART_USER schema.
  8. When the process is complete, a confirmation message appears with the latest version of Oracle Argus Mart.
    The following is created as per the values specified in the dbinstaller.properties file:
    • Users
      • AM_MART_USER
      • AM_STAGE_USER
      • AM_APP_USER
      • AM_ETL_USER
      • AM_VPD_ADMIN
      • AM_BI_USER
    • Roles
      • AM_VPD_ADMIN_ROLE
    • Factory Data
      • Out-of-the-box Factory data is loaded into tables such as ETL_SIGNAL_TABLE_MAPPING and RM_CMN_PROFILE_GLOBAL.
    • Database Links, DB_LINK_ARGUS:
      • From AM_STAGE_USER of Oracle Argus Mart to AS_MART_USER of Oracle Argus.
    • Tablespaces
      Note that the tablespace names begin with AM.
      The DBInstaller creates the following tablespaces for the Oracle Argus Mart database, when you create Oracle Argus Mart schema:
      • AM_APP_DATA_01
      • AM_APP_INDEX_01
      • AM_APP_LOB_01
      • AM_MART_DATA_01
      • AM_MART_INDEX_01
      • AM_MART_LOB_01
      • AM_STAGE_DATA_01
      • AM_STAGE_INDEX_01
      • AM_STAGE_LOB_01
