Configuring Case System Numbering
- Go to
System Configuration > System Numbering > Case
. - Enter the fields as described in the following table.
- Click Save.
Field Descriptions - Case System Numbering
Field or Control Name | Description |
Manually Number Cases |
Enables you to manually number the cases on booking or while copying the case, using the Save As option on the case form. |
Automatically Number Cases |
On selection, the system automatically numbers the cases as defined by you in the numbering format. |
Start at |
Enables you to initialize the counter of the sequence number for automatic case numbering. |
Separate sequence for each site |
Enables you to separate the sequence numbering for cases on site by site basis. If there are cases being entered from two different sites then each site will have different sequencing of case numbers. |
Separate sequence for each report type |
Enables you to separate the sequence numbering for cases by the report type of the case. |
Separate sequence for each year |
Enables you to reset the sequence numbering for cases after each year based on the initial receipt date of the case. |
Separate sequence for each month |
Enables you to reset the sequence numbering for cases after each month based on the initial receipt date of the case. |
Separate sequence for each product abbreviation |
Enables you to reset the sequence numbering for cases for each different product abbreviation. |
Numbering Format |
Enables you to select the numbering format by selecting the different placeholders. Define the numbering format by typing in custom keywords to print on every case number and selecting different placeholders. Alternatively, you can click on each placeholder in the order that you require for them to appear on the case. [YY][MM]-[####] is the default format. |
Placeholder |
Placeholders are used to pickup values from the database to be used in the case numbering format. The possible values populated in this list are:
Parent topic: Configuring System Numbering
