Button and right-click options
| Button | Description |
ICSR Viewer |
Select this right-click option to launch the ICSR viewer. Note: At the time of generating an ICSR report, some characters entered in the case form may not be displayed the same in the ICSR report. For the example:The ICSR report equivalent of the "&" character entered in the case form is &. Similarly, there are other such characters that are represented differently in the ICSR report. |
View Error/Warning Message |
Select this right-click option to view all warning messages including M2 validation errors and Multiple ICSR Codes log. |
Accept ICSR |
Selects the incoming ICSR report for both single and multiple acceptance. Execute these steps to accept an ICSR Case:
After you click OK, the report is queued and then it moves through the following stages: Queued, Proccessing, Failed and Retry in Progress. Accepting Amendment report is the same accepting a Follow-up report. The application
supports importing attachments for the file types as configured
in the profile switch |
| Reject | |
View Validation Failure |
Opens the ICSR validation report (pdf) in the same format as it does at the time of export. This validation report prints all the validations that are categorized as soft validations for the import. Applicable for (R3) based ICSR reports only. |
Duplicate Search |
Select this right-click option to perform Duplicate Search for the case being imported with the case present in the system. |
Parent topic: Track incoming ICSR reports
