How does the Lock State Column under Reports > Compliance > Expedited allow me to sort my cases?
Click the Lock State header row to sort on the following category of cases. A pop-up window appears, with the following sorting options:
- Lock State
- SUSAR
- Exp/Per
Click the required option to sort cases based on the selected case categorization.
Lock icons
| Icon... | Identifies... |
A case marked for a Periodic ICSR submission. |
A locked case. |
An unlocked case |
A SUSAR (Suspected Unexpected Serious Adverse Reaction) case. |
Lock icon options
| Field | Description |
Report Details |
Displays specific information about the report as entered in the Regulatory Reports section. The information displayed in the fields of the Report Details dialog box is fetched from the data entered in the Regulatory Reports section of Case Form. |
Parent topic: FAQs
