Common Features in Medical Review
The following table lists and describes the common features under Medical Review.
| Field | Description |
Generate |
Click Generate in either of the narrative fields to enable Auto Narrative Generation. |
Return Case |
Click Return Case to open the return route dialog and save the information. |
Forward Case |
Click Forward Case to open the forward route dialog and save the information. When the case has been routed and the form is closed, you cannot route from the case form Activities tab till the case has been closed and re-opened. |
View Draft |
Select a report and click View Draft to generate a draft version of the report based on the open case. Note: This report form type is saved as a default and the next time the user opens the Medical Review for another case, this is defaulted to the Report Form selected previously.The Draft report does not display all the changes made to the Case until the case has been saved in the database. |
Zoom/un-zoom icon |
Click the Zoom icon to view the selected dialog on a much bigger scale. Click Un-Zoom icon to revert back to the earlier view. |
Parent topic: Medical Review
