Report Execution Flow from Oracle Argus Safety
To execute a report using the Oracle Argus Safety user interface:
- Select a report configuration from Oracle Argus Safety Aggregate Reports library.
- Click Print and select the required parameter from the batch print screen.
The report executes as follows. The system:
- Adds an entry into the Oracle Argus Safety database for status tracking.
- Generates and stores the various case series.
- Sends the request to the Oracle Analytics Publisher server.
- Populates the temp tables based on the selected report parameters.
- Before the temp tables are populated, verifies the user exits, and updates the temp table data.
- Generates the report output.
- Stores the report output in the Oracle Argus Safety database.
- Adds an entry into the common regulatory reports table along with a link of the report output.
- Updates the status in Oracle Argus Safety database and mark the report as generated.
You can view the report output from Oracle Argus Safety.
