Report parameters for running Oracle Analytics Publisher reports through Oracle Argus Safety
While you run a report through the Argus Safety Report Batch Printing window, you can schedule the report in Oracle Analytics Publisher for an instant or a future run.
A report template must be selected in the Report Batch Printing window. This template is used to schedule reports in Oracle Analytics Publisher. The following parameters are passed from Argus Safety to Oracle Analytics Publisher while you schedule the report:
Parameter | Description |
Enterprise ID |
The enterprise ID for which you run the report. |
Report Configuration ID |
The report configuration ID selected to run the report. |
User Name |
The name of the user that runs the report. |
Report Format |
Specifies the report format. |
Print As |
Specifies the mode to run the report. If you select Other, you need to specify the watermark value as well. |
Parent topic: Run Reports through Oracle Analytics Publisher Console
