Configuring Products
The following table lists the Japanese specific fields in the Product screen:
Field | Description |
J-DRUG
Captures the J Drug Code for each ingredient of the product. This field is configured from Argus Console > Business Configuration > Product and Licenses > Product (J Data Entry) > Key Ingredients > J-Pop-up.
医療機器の一般名 (Device Generic Name) |
Provides the Device Generic Name from the JMDN glossary. |
JMDNコード (JMDN Code) |
Provides the JMDN Code from the JMDN glossary. |
使用辞書コード (Terminology Code) |
Provides the Terminology Code from the JMDN glossary. |
J-DRUGコード for Product (J Drug Code or OTC Code or Temp Code) |
Provides the J Drug Code from the Drug Coding dialog box. You can manually configure the OTC Code or Temp Code if the J Drug Code is not available for the product. |
The other fields on this window, such as Product Name (J) or Ingredient Name (J) are equivalent Japanese values to the corresponding English fields.Parent topic: Business Configuration
