Setting Ready for Build
Once the final has been generated, reviewed, and approved the report reviewer and/or report owner can indicate whether the template section is ready for the report build. Ready to Build must be checked for all sections of the report before the system can build the report.
To indicate a template section is ready for the report build:
- Select Reports > Compliance > Periodic to display a list of periodic reports.
- When the application opens the list of periodic reports, locate the appropriate report and click its associated report icon.
- Select View Argus Dossier from the pop-up menu.
- When the system opens the Author tab for the selected report, locate the appropriate template and click the associated check box in the Ready for Build column.
Parent topic: Processing Dossier Reports
