Setting Ready for Review
Once the final has been generated, the report author can indicate whether the template section is ready for review.
- Select Reports > Compliance > Periodic to display a list of periodic reports.
- When the application opens the list of periodic reports, locate the appropriate report and click its associated report icon.
- Select View Argus Dossier from the pop-up menu.
- When the system opens the Author tab for the selected report, locate the appropriate template and click the associated check box in the Ready for Review column.
- When the system opens the Ready for Review dialog box, click Yes.
- The system places a checkmark in the check box and enables the Check Out button.
Parent topic: Providing Report Content
