Using Templates
When using templates, be aware of the following:
- The application parses template elements sequentially. This prevents elements from being used before they are declared.
- The order in which the templates appear on the template tab is the order in which they will appear on the generated report. If you need the sections in a different order, use the Up and Down keys to change their position.
You should assign users (authors, reviewers, and owner) to each template section.
For more information, see:
