Installation and Administration Guide Installation Configure Oracle Data Integrator Settings Validate the Load Plan Validate the Load Plan To validate the Load Plan, execute the following steps: Select Operator tab. In the Load Plans and Scenarios > LP_ARGUSMART section, double-click the LP_INI_AM Load Plan. If the Object Locking dialog box appears, click No and proceed with the Validation process. The Load Plan details appears in the right pane. Click Validate. A confirmation message appears, if there are no issues associated with the Load Plan. Parent topic: Configure Oracle Data Integrator Settings
