Are FDA Coding and IMDRF done separately for Device Problem and Evaluation/Investigation Code Information?
New CFG_FDA_IMDRF_CODES repository supports harmonized IMDRF and FDA Codes for Medical Device Problem (Annex A) and Evaluation/Investigation Codes (Annex B, C, D). When you use the lookup and select a record, the system stores FDA Code and corresponding IMDRF code, ensuring Common Coding for the IMDRF and FDA Codes.
Parent topic: Frequently Asked Questions
