Dictionaries management using the Dictionary Management Tool
The Dictionary Management Tool is used to load and update the dictionaries in Argus.
For each dictionary, you need to create a schema with the Dictionary Management Tool and then load the dictionary.
| Schema Name | Action |
MedDRA Schema |
To enable MedDRA, create this schema by using the MedDRA Loader option when MedDRA is loaded to the new database tables. |
WHO Schema |
To enable WHO, create this schema by using the WHO Drug Loader option when WHO is loaded to the new database tables. |
J Drug Schema |
To enable J Drug, create this schema by using the J Drug Loader option when J Drug is loaded to the new database tables. |
For more details, refer to the Oracle Argus Safety and Oracle Argus Insight Installation Guide > Create Argus Safety Database Schema.
In this section:
