Search duplicates for incoming review
The Duplicate Search in Argus Central Incoming review enables you to search on Reference ID and Keyword field in Oracle Argus Safety cases.
You can right-click the Case Number for a listed case and use the following options:
| Right-click Option | Description |
Case Form Print |
This option is displayed for only those users who belong to the group with access to
This option allows you to print the case form report. |
Case Summary |
This option allows you to open the summary report of the case. |
Medical Summary |
It displays the medical summary of the case. |
Unlock/UnArchive Case |
This option is displayed to allow users to re-open the archived and locked cases. On clicking this option, a Locked Case/Archived Case screen (as applicable) is displayed. You need to enter your password along with any remarks/notes and select a reason for your action to complete the unlocking/unarchiving of the case. Note: This option is available only when the case is in locked/archived status, and if the user has privileges to lock/close the case, as perArgus Console User Configuration > Case
Form settings.
Parent topic: Search for duplicate reports
