Request adding a trading engine node
Before starting to create communities and trading partners, you need to have a trading engine (TE) node implemented in your Axway B2Bi environment.
A TE node is an instance of a Java virtual machine that performs the work of the application. The Oracle team implements the TE node in your Axway B2Bi environment by your request.
You need to request a TE node only once, before creating the first community.Follow the next steps to create a change request ticket for adding a TE node.
Parent topic: Before you begin configuring Axway B2Bi
