- User's Guide
- Process case data
- Review cases
- Perform a medical review of a case
- Hover over the Case Actions menu, and click Open.
- On the Case Selection page, enter the search criteria for a case and click Search.
- From the results list, select a case.
- Hover over the Case Actions menu and click Medical Review.
- In the Medical Review - Case Form dialog box, to add a
narrative to the case:
Manually fill in the Narrative text box.
Tip:
To enter the narrative in a specific language, click the icon representing the language above the text area.
Alternatively, to fill in the Narrative text box with text from an auto narrative template, click Generate.
- In the Custom Auto Narrative Templates dialog box, select a template from the list of available templates and click Append. To replace the selected template with a new auto generated narrative template, click Replace instead.
- To add information in addition to the narrative, click the
Case Comment icon (
). - If the case has events that are encoded using the MedDRA dictionary, select either D for Diagnosis or S for Syndrome from the D/S field.
- To switch to data sheet view and display the License column, click the
+ (plus) icon for Datasheet.
Revision number and date on which the Datasheet was made active are also displayed.
- To view a read-only version of the case, click the Temporal View tab.
- Filter the data categories to appear in the Event Assessment section by checking the corresponding checkboxes in the Display Options section.
- To view details for an event listed in the Event Assessment section, click the Info icon for the event.
- Enter information about any relevant tests performed in the Relevant Tests field in the associated section.
- To attach notes and other items to the case, or to create cross-references to other cases, click the Action Items/Addl Info tab.
Parent topic: Review cases
