Scale and Layout
The supported scale (zoom) is 100%. Consider the following:
- Distortion or truncation of UI display of Argus may occur if scale is not set to 100%. The recommended display resolution is minimum 1280 x 1024.
- Depending on the device used (monitor/laptop/etc.), the supported layout may vary. Set the resolution according to your monitor settings.
Disable the Pop-up blocker in the Advanced settings section of your browser.
Disable the Save and fill addresses option in the Settings section of your browser.
Parent topic: Know your basics
