- Installation and Administration Guide
- Installation
- Create the Oracle Argus Mart Database Structure
- Install Oracle Argus Mart
- Create a Fresh Oracle Argus Mart Schema
- Log in to the Oracle Argus Mart Server with administrator privileges.
- Navigate to
...\ArgusMart\Database\DBInstaller
. - Open
Dbinstaller\dbinstaller.properties
file. - Modify the following parameters:
Mart Database:
- db_connect_string—connects to the Oracle Argus Mart database.
Syntax:
db_connect_string=<host>:<port>/<service name>
For example:
server.us.xx.com:1521/AM84MT
or
server.us.xx.com:1521/AM84MT.us.xx.com
- dba_user—specifies the name of the Install user to run Oracle Argus Mart Liquibase Install.
- default_datafile_directory—default location on the database server, where datafiles will be created.
Mart User of each schema, where password is optional:
- appschema_sm_mart
- appschema_sm_stage
- appschema_sm_app
- appschema_etl_user
- appschema_rls_user
- appschema_bi_user
Safety Database:
- safety_db—Oracle Argus Safety database instance name
- safety_ro_user—Oracle Argus Mart Read-only user created in Oracle Argus Safety
For more information on these parameters, see Overview of the dbinstaller.properties file.
It is recommended that you preserve the default names for tablespaces and roles.
- From the command prompt, go to DBInstaller directory.
- Type
dbinstaller.bat
, and press Enter.The Liquibase install begins, and the parameters (as entered) appear on the command prompt screen with password in the hidden mode (****).
- Keep monitoring the Liquibase progress by querying the Liquibase Log table
mart_dbchangelog
, created inAM_MART_USER
schema. - When the process is complete, a confirmation message appears with the latest
version of Oracle Argus Mart.
The following is created as per the values specified in the
file:- Users
- AM_MART_USER
- AM_STAGE_USER
- AM_APP_USER
- AM_ETL_USER
- AM_VPD_ADMIN
- AM_BI_USER
Roles
- AM_VPD_ADMIN_ROLE
Factory Data
- Out of the box Factory data is loaded into tables such as ETL_SIGNAL_TABLE_MAPPING, RM_CMN_PROFILE_GLOBAL, etc.
- Database Links, DB_LINK_ARGUS:
- From AM_STAGE_USER of Oracle Argus Mart to AS_MART_USER of Safety.
- Tablespaces
Note that the tablespace names begin with AM.
The DBInstaller creates the following tablespaces for the Oracle Argus Mart database, when you create Oracle Argus Mart schema:
- AM_APP_DATA_01
- AM_APP_INDEX_01
- AM_APP_LOB_01
- AM_MART_DATA_01
- AM_MART_INDEX_01
- AM_MART_LOB_01
- AM_STAGE_DATA_01
- AM_STAGE_INDEX_01
- AM_STAGE_LOB_01
- Users
Parent topic: Install Oracle Argus Mart
