View the Steps of Load Plan
Before executing the Initial ETL, you may view the steps of the Load Plan for the Initial and the Incremental ETL.
To view the steps of Load Plan, execute the following steps:
  1. Log on the Oracle Data Integrator Console, and select the Management tab.
  2. Navigate to Runtime > Scenarios/Load Plans > Folders > LP_ARGUSMART.
  3. Right-click LP_INI_AM (Load Plan for Initial ETL) or LP_INC_AM (Load Plan for Incremental ETL), and select View.
    The steps for the Load Plan appears in the Relationships section in the right pane.
