Load an IMDRF Drug dictionary
To load an IMDRF dictionary:
  1. From Argus Console, go to Tools, click Dictionary Management and select Dictionary Loader.
  2. Select Load New.
    The Dictionary Management Tool performs same action on Load New and Overwrite for the IMDRF drug dictionary.
  3. In the Dictionary File (.zip file containing dictionary data) field, select the local path to the Dictionary ZIP file.
  4. Select the dictionary type. The list is populated based on the Dictionary Type factory codelist.
    The Configuration File section does not display any value as the configuration file is not required for IMDRF dictionary load.
    The Version field remains blank and is disabled. When dictionary load is successful, the version is auto populated in the bottom section of the screen.
  5. In the Notification Email Address field, set the email address you want to receive an update on the load operation status after completion.
  6. Click Load.
  7. When the load is complete, download the log.
For more information about the Dictionary Loader window, see Dictionary Loader field descriptions.
