Initial case entry—BookIn dialog box
  • You can enter the attachment classifications and their descriptions on the Initial Case entry dialog box.
  • The values entered in the Classifications and Description fields are transferred after the cases have been booked.
  • When you book in a clinical trial case and select a study where the country of incidence value does not match the list of countries defined in the study configuration, a warning message appears.
  • Right-click the row, and select one of the following:
    • View Case Summary
    • Print Medical Summary—Displays the Medical Summary report PDF. If you do not have access to the Medical Review dialog box, the Medical Summary Report is hidden.
    • Print—Launches the Case Form print dialog box. If you do not have access to the Case Form print dialog box, the Print Case option is hidden.
  • A file scan is performed while uploading files directly to Argus Safety. This scan is asynchronous: you can upload files and continue working while the scan runs in the background. Until the file scan is complete, a yellow dot icon is displayed to indicate that scanning is in progress. Once the scan is complete, a red dot icon is displayed to indicate that the file is malicious, if identified as such or if the scan failed for any reason. Case save is not allowed until you delete the malicious file and an error message is displayed.
