Print case details for a case Hover over the Case Actions menu, and click Open. On the Case Open page, enter the search criteria for a case and click Search. From the search results list, click a Case ID link. Hover over the Case Actions menu, and click Print. To print the Case Form for the case: Select Case Form. From the Print Case dialog box, check the checkbox for each section to print or check the Select All checkbox. If you don't want the print to include product information for the case, check the Blind Study Product checkbox. Click Print. To print the Medical Summary for the case: Click Print Medical Summary. From the medical summary report, select File and then Print. Parent topic: Process cases
