Sharing a case series in Oracle Argus Safety with Oracle Argus Insight In the Case Search dialog box, search for and select a case in Oracle Argus Safety. Open Oracle Argus Insight.The system writes the case series belonging to the alert to the Argus case-sharing table. Check Make Active from Argus to make the Case Search dialog box case series active in Oracle Argus Insight. If Oracle Argus Insight was already open, the Active Case series in Oracle Argus Insight is replaced with cases from Oracle Argus Safety. Parent topic: Integrate with Oracle Argus Insight
