PreviousNext
JavaScript must be enabled to correctly display this content
Running the installation
Open a Command Prompt window and navigate to the installation folder on your
local machine.
Run the following command: ...setup.exe -s -f1"[Location of
response file]\[Resonse file name]"
-f2"[Location of log file]\[Log file
name]"
In the command syntax:
Location of response file—The directory where the
response file you modified exists.
Response file name—The name you gave the response
file to use during the silent installation.
Location of log file—The directory where you want
the log file to be created.
Make sure the directory exists;
otherwise the installation fails.
Log file name—The name to give the log
file.
The log file is automatically created during the
installation.
After you run the silent installation, Oracle recommends that you check the log file to ensure that the installation was
successful. For more information, see Checking the log file
