Features and Limitations
Features
- Provides the ability to monitor jobs by subject.
- Allows for parallel processing of subject data.
- Includes email notifications sent for failed jobs.
- Data is processed in the order requests are received.
If the current job is in a failed status, new jobs for the same subject remain in a blocked status until the failed job either succeeds or is canceled. - Has the ability to create subjects in Oracle Clinical One Platform.
Limitations for visits, forms, and items
- Data upsert into frozen items is not supported.
An upsert is a database operation that updates an existing row if a specified value already exists in a table, and inserts a new row if the specified value doesn't already exist. - Importing data into unscheduled and cycle visits is not supported.
- Importing data into dynamic visits, forms, or other items is not supported.
- Importing data into two-section forms is not supported.
Limitations for repeating forms
- Deleting a row on a repeating form is not supported.
- Only those rows inserted through the integration for, Screening, VisitComplete, and AdverseEvent can be updated.
- Updating or deleting manually added rows for repeating forms is not supported.
- The data value for items defined as the primary identifier(s) cannot be updated.
Limitations for subjects
- All imported subjects will be created in a single site in Oracle Clinical One Platform, as ObvioHealth does not support multiple sites.
- Patient transfers are not reflected in the data transmitted through the integration with Oracle Clinical One Digital Gateway.
- Data relating to subject status changes is not supported.
Limitations for branch visits
- Branch visits are added in sequence starting from instance 1; Design settings of cycle start are not taken into account.
- Partial dates cannot be used as visit start date values.
Parent topic: ObvioHealth Integration
