Select Security from the
Navigation menu in the upper right corner of Oracle DMW.
The page refreshes to display the Security
interface. The Roles tab is selected by
default.
Search for the role you wish to assign operations to in the left panel and
click the role to select it.
Tip:
Click View All Assignments above the
search function in the left panel to see which operations are currently
assigned to the selected role.
Select a Functional Area from the center panel. To see
all available Functional Areas, click the Include internal Functional
Areas checkbox.
After selecting a Functional Area, the right panel refreshes to display
any operations within the selected Functional Area already assigned to that
role.
Click Manage Assignments to add or remove
operations.
A Manage Assignments panel is displayed on the
right.
Enable the checkbox next to each operation you want to add to the role. If you
want to remove an operation, de-select the checkbox.
