REQUIRED_ROLE_FOR_DMW
To manage Object Security in Oracle DMW, you'll need to assign REQUIRED_ROLE_FOR_DMW to an Administrator. The Oracle LSH Object permissions required to use Oracle DMW's Security interface are automatically assigned to this role.
| Object Type | Object Security Permissions |
| Adapter Area |
| Adapter Domain |
| Application Area |
| Business Area |
| Business Area Instance |
| Variable |
| Data Mart |
| Data Mart Instance |
| Execution Set-Up |
| Instance Domain |
| Loadset |
| Loadset Instance |
| Notification |
| Output |
| Parameter |
| Parameter Set |
| Program |
| Program Instance |
| Table |
| Table Instance |
| Work Area |
| Workflow |
| Workflow Instance |
| Workflow Structure |
Parent topic: Predefined object security roles
