Modify an Execution Setup
Use this API to modify an Execution Setup. You can change an Execution Setup's name and description. You must check out the Execution Setup before modifying it.
Name
CDR_PUB_DF_EXECUTIONSETUP.ModifyExecutionSetup
Signature
PROCEDURE MODIFYEXECUTIONSETUP( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
          CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Execution Setup and enter new
          values for the attributes you want to modify. All attributes are required.
Use separate APIs for modifying the validation status and the version label: CDR_PUB_VL_VALIDATION.UPDATEVALSTATUS and CDR_PUB_DF_NAMING.UPDATEVERSIONLABEL.
Parent topic: Create and Modify Execution Setups
