Modify a Notification Definition
Use this API to modify a Notification definition. You need to check out the Notification definition first.
Name
CDR_PUB_DF_NOTIFICATIONS.ModifyNotification
Signature
PROCEDURE MODIFYNOTIFICATION( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDRNOTIFICATION IN CDR_NOTIFICATION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
          CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
Initialize the attributes COMPANY_ID, OBJECT_ID, and OBJECT_VER.
 - PI_CDRNOTIFICATION (Mandatory) This is a parameter of table type CDR_NOTIFICATION_OBJ_TYPE. Provide values for the attributes you want to modify.
Parent topic: Create and Modify Notifications
