Set the Resource Timeout Limit
Use this API to set the current session timeout limit for all user database accounts (for example, change the default limit of 24 hours to 8 hours). This parameter has a default of 180 minutes with a minimum of 30 minutes and a maximum of 1440 minutes (24 hours)
Name
CDR_PUB_ResourceLimits.setResourceLimit
Signature
PROCEDURE setResourceLimit ( p_api_version IN VARCHAR2 , p_init_msg_list IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE , p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE , p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL , x_return_status OUT NOCOPY VARCHAR2 , x_msg_count OUT NOCOPY NUMBER , x_msg_data OUT NOCOPY VARCHAR2 , p_name IN VARCHAR2 , p_value IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- P_NAME (Mandatory) Enter the current
                                                  value set for the database profile name.
                        - CONNECT_TIME
- P_VALUE (Mandatory) Enter a minimum of 30 minutes and a maximum of 1440 minutes (24 hours). (The default is 180 minutes [24 hours]).
Parent topic: Create and Modify Security Policies
