4 View data listings, display data flow, and create discrepancies
- Choose a listing type
- Search for data
- Review data
- Customize the listings or discrepancy views
You can hide, pin, or reorder columns on the Listings page or Discrepancies interface by using Table Settings function at the top of the grid. - Create discrepancies
- Reprocess discrepancies that failed to be sent
- Export data to Excel or CSV
After you select a study and open a listing, you can export the data. To export the data in a listing, click Export from the top of the listing table to open the Export Listings options. - View data flow
- Create a custom listing
- Copy a custom listing
- Use the Expression Builder
- FAQs
