Create InForm Users
On each InForm database with a study you plan to use Oracle DMW:
- Log in to UMT using an account that can create new users, such as
system. - Create a user with a suggested username DMW_AUTH to be used for authentication purposes by the web service connection. This user does not need any privileges. Its username and password will be used within Oracle DMW when creating web service locations.
- Create a user with the required name DMW_QUERY to be used for sending and
updating discrepancies in InForm.
- Make DMW_QUERY a sponsor user
- Assign the DMW_QUERY user to a query group.
It is not required to give the DMW_QUERY user access to sites or even be part of a rights group that can manipulate discrepancies. The password for this user is not used in Oracle DMW.
- Activate both accounts.
Parent topic: Set Up the InForm Adapter
