Create a Managed Server and Assign it to the Machine
During domain creation, create a managed server with the suggested name
DMWServer and assign it to the Oracle DMW machine.
Create an additional managed server with the suggested name
DMWServicesServer and assign it to the new Oracle DMW machine DMWServicesMachine. This is required to
configure and deploy DMW Services - Data Flow Diagram and Discrepancies
Export. This helps to improve the performance of the application.
Due to any hardware or other constriant, if you cannot create DMWServicesServer , then configure the DMW Services on the DMWMachine itself.
The instructions in the following sections refer to this managed server as DMWServer and the machine as DMWMachine.Parent topic: Create a WebLogic Server Domain for Oracle DMW
