Run the Driver Script
The driver prompts for all required input parameter values and calls the other scripts as required.
- Log into SQL*Plus with an account with DBA privileges.
- Go to the directory that contains the downloaded scripts.
- Execute DMWInFormInstall.sql. The script prompts for:
- A name to give the log file.
- TNS name or connect string for the InForm database. If you enter the connect string, do not enter any spaces.
systemor other DBA username and password.- Name of the Oracle DMW Admin account to be used or created for the purpose of giving privileges to the Oracle DMW read-only access account. The system creates the account if it does not already exist.
- Name of the Oracle DMW read-only access account to be used or
created. The system creates the account if it does not already exist.
Do not use spaces or special characters other than underscore (_) in the username or password. - Passwords for both accounts. If the accounts are new, the script prompts you to confirm each password. If the accounts already exist, you must enter a password, but the system does not change the existing password. It proceeds to create or update the packages owned by the schema.
- If the read-only access account is new, the script also prompts for a tablespace name. It then creates a tablespace on the InForm database to be used for the integration with Oracle DMW and creates or updates all Oracle DMW objects in this tablespace.
