Data Auditing
In Oracle LSH, you can select a data processing type that provides an audit trail of changes made to the data. With Oracle LSH audited data, you can recreate the state of data in the table at any previous point in time using data snapshots. The audit trail never deletes data. But, it records each change to each record over time, including data deletions.
Oracle DMW maintains a full audit trail for all changes made to data. You can display the most recent Oracle DMW data in the Oracle DMW application. Data from the audit trial is visible in Oracle LSH.
Parent topic: Auditing and Monitoring
